Monitoring Auto Trans Fluid Thermal Degradation
  • Monitoring Auto Trans Fluid Thermal Degradation
    There is a parameter used on the new 150kw Prado/Hilux/Fortuner ECU that tracks the estimated thermal degradation of the Auto Trans Fluid which from reading online would be a good indication of when it should be changed if you are not doing it based on km's..
    The info I have read indicates that a figure of >49999 is bad and the ATF should be changed and a Scantool used to reset the estimated figure to baseline.
    There is also a Torque Converter Temperature Raise History value but I haven't found any info on what that tells us, so not sure how useful it is.
    The relevant codes for Scangauge II:
    ATF Thermal Degradation Estimate
    TXD 070022162B
    RXF 04620516062B
    RXD 3010
    MTH 000100010000
    Name ATD
    TXD 070022162C
    RXF 04620516062C
    RXD 3008
    MTH 000100010000
    Name TCR
    and Torque Pro:
    OBD2 Mode and PID: 22162B
    Long name: ATF Thermal Degradation Estimate
    Short name: ATF Degrad
    Min value: 0
    Max value: 65535
    Scale: x1
    Unit: –
    Equation: A*256+B
    OBD Header: 700
    OBD2 Mode and PID: 22162C
    Long name: Torque Converter Temperature Raise History
    Short name: TCT Raise
    Min value: 0
    Max value: 255
    Scale: x1
    Unit: –
    Equation: A
    OBD Header: 700
    Would be interesting to see what sort of values everyone is seeing at various km and usage (mine at approx 25000km with a trans cooler fitted at startup are ATD 293 and TCR 0 haven't monitored while driving yet).
