DAC grinding noise....normal?
  • DAC grinding noise....normal?
    Google search says this is normal - mod pls delete
    guys
    I did a search for DAC but nothing came up so here goes
    I used DAC for the first time on the weekend. Nothing major just general bush track to see how it works.
    It sounded awful! It was like a loud grinding noise in the drive train before the brakes were applied? Is this normal? Should it sound like this or do I have a problem with the drive train somewhere?
    Re: DAC grinding noise....normal? MOD PLS DELETE
    Probably worth keeping, atleast I wont s^*t myself when I use it for the first time.
    Alan.
    P.S. Anyone know why it makes this noise?
    [color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
      The noise is from your brakes. The engine is trying to drive the wheels through the pulsing ABS.
      Mick
        I had the same reaction first time we used DAC. :shock: :shock:
        On a flatter road just increase the vehicle speed setting and the noise from the brakes reduces significantly. After a bit of playing around in the bush found it is very noisy down hill as it is using the brakes more to control the wheel speed. Noise also increases if there is any wheel slip or spin. The noise is just the brakes being applied via the ABS and then released again.
        Prado 150 Kakadu, D4D 5-Spd Auto, Silver, Full Window Tint, Hayman-Reese Towbar, Rhino-Bars, GME TX3400 radio, ARB Deluxe Combination Bar, Hella 2000 Driving Lights. PE Brake controller and Complete Campsite XT Camper Trailer
          Even worse when the brakes are wet.
            The manual says it is noisy. says it is normal.
            Regards
            Crisp Image
            GX 150 with 3rd row seats, Milford Cargo Barrier, factory roof racks,Tekoncha P3 & a duel battery system..
              Yep, perfectly normal.
              Most of the time L1 will get you down a hill, but it's nice to know the DAC works and it does make navigating the odd tricky decent a lot easier.
              Dave [url=http://www.fuelly.com/driver/DAdeGroot/prado][img]http://www.fuelly.com/smallsig-metric/50650.png[/img][/url]
              2010 V6 GXL with extras
              David de Groot Photography
              [url="http://www.degrootphotography.com.au/"]http://www.degrootphotography.com.au/[/url]
                i too have used it down some tricky slopes - worked an absolute treat.
                it did sound horrible though - a lot worse than the TC.
                at times i had to turn it off cause i was descending too slow!! (this isn't be a bad thing though)
                louie
                Silver 150 GXL V6 Auto: TJM T13 bull bar, Avenger Mako TDS 9.5 winch, 2" lift - Bilstein shocks King springs, factory tow bar, Piranha battery tray, Red Arc isolator, E-Nex DC24MF battery, GME TX3540 UHF, ARB 47L fridge, ARB fridge slide, IPF spotties, Tekonsha P3 brake controller
