Interior Light replacement and LED upgrade
  • I had trouble with the map lights too.
    I used the sticky tape method. Works well if bulbs are clean, ie Not greasy from fingers.
    Check this clip out to see how it is done.
    https://www.youtube.com/watch?v=mXz0e_QB1F4
    • Has anyone had to replace the main light switch up in the front assembly in a GX? Flicked it from "door" to "off" the other day and now the switch seems to be stuck in "off" mode. Opening any door including the boot doesn't cause the lights to come on. Centre and rear "on" switches do still work but not "door" mode. Front switch seems a bit wobbly too.
      • Originally posted by Damienandwendy View Post
        I am looking at upgrading all the interior lights to an LED equivalent and trying to figure out how to remove the clear covers.
        As the bus is still newish and sort of shiny, I don't want to get too excited with a flat blade screwdriver, but I guess that might be the only option.
        Looking at LED's from http://www.ledshoponline.com as I have purchased from them before and very happy with the price, quality and light output.
        cheers
        bro i hv a 2011 prado i wanted to the light specifications of the interior lights
