Has anyone tried putting a match in the interior light switch for the drivers door so the switch is held in? I assume it's the interior switch on the drivers door which triggers the chime. Of course you'd lose the interior light at night.
Disabling the door chime
I've taped mine up with duct tapeOriginally posted by Kowolski View PostHas anyone tried putting a match in the interior light switch for the drivers door so the switch is held in? I assume it's the interior switch on the drivers door which triggers the chime. Of course you'd lose the interior light at night.
2011 150series GXL
Any idea as to what they did??Originally posted by Kowolski View PostPicked up my Kaka yesterday and asked them to disable the door chime. Did t not probs[I]cheers..... Rob (macca)[/I]
[B][I][COLOR=Green]Car-2: 1993 Suzuki Vitara 4Dr (modified for Playing) [/COLOR][COLOR=#ff0000]Now Retired[/COLOR][COLOR=Green]
[/COLOR][/I][/B]
Might have to quiz them at the next service then..... or is this a Kakadu model only feature??Originally posted by Kowolski View PostThey just program the chime out in the ECU. Like how they cab program the remote to open/close the windows. Also, I you get the window feature from the remote function enabled, you can choose whether it includes the sunroof.[I]cheers..... Rob (macca)[/I]
[/COLOR][/I][/B]
Doing this mod.... does it stop ALL beeping ??[I]cheers..... Rob (macca)[/I]
[/COLOR][/I][/B]
Hi there,
To stop the “Ding Ding” I fitted a small “Rocker Switch” ( from Jaycar) in the “B Pillar”, which allows me to select wether or not I want the “Ding Dings” to operate.
The “Rocker Switch” fits reasonably flush with the pillar trim, less chance of being bumped accidentally.
A couple of tips:-
Cut the existing door switch wire as far from the switch as possible, so the wiring doesn’t foul the seat belt behind the “B Pillar Panel”.
Solder the joints & cover with “Shrink Spaghetti”.
Fit the switch far enough towards the back of the pillar so it doesn’t foul the seat belt.
Links for pics.
This is not my idea, Phil, who I met at Charters Towers a few months ago gave it to me & it works a treat.
http://i684.photobucket.com/albums/v...a/DSC09906.jpg
http://i684.photobucket.com/albums/v...a/DSC09905.jpg
http://i684.photobucket.com/albums/v...a/DSC09907.jpg
Tar Trek.Last edited by Tar Trek; 06-08-2012, 08:46 PM.
I know this is old now but i'm suffering the same affliction! If i cant get Toyota to disabled the chimes im going to go down the screw method.
When i click on the pictures from Wazza2 they are so small and blurred, i can see there's text on the images but cannot read anything. Does anyone have a link to the actual full size pictures? I'm a follow the pictures kinda person
If the door chimes when open you just push the rubber button in the door jam it goes off[B]Black '09 150 D4D GXL[/B]. ARB Winch bar, OME 2"lift, ARB underbody protection, Rock Armour sliders, Runva 11XP Winch, ARB CKMA12 air Compressor, dual batteries, Optima 55ah battery, Safari Snorkel, WetSeat Covers, Outback Ideas Recovery Points, 17x8 Dynamic Wheels, BFG Muddies 265/70r17, Awesome home made rear draws with fridge box & ARB slide, KAON transfer &a actuator guard, ARB front & rear lockers,
Some larger ones for you!Originally posted by Gogetter View PostDoes anyone have a link to the actual full size pictures? I'm a follow the pictures kinda person
