ARB dual battery setup
  • ARB dual battery setup
    Hi all,
    Here are some photos of my ARB second battery installation
    The battery is a D34 Optima Yellow, on a ARB tray, mounted on the driver side spot:
    Isolation/charging is done via a REDARC BCDC1220, mounted on the side:
    They also run the cable to the back (6mm with 15A fuse). You can see the inline fuse in the photo:
    The cable is run across the engine bay:
    Here is the original battery with the connections and 20A circuit breaker:
    I had them terminated the cable on a Hella and Cig lighter sockets at the rear (Like what Derek from ABR did):
    The setup seems to work ok, powering an ARB 47L fridge at the back. The fridge connection via the Hella socket is a bit loose, not sure if this is because of the side-way connection or I just have a loose socket.
    I actually bought a REDARC SBI isolator and was going to do the installation myself, but after looking at the cost of all bits and pieces, potential electrical warranty/insurance issue (I was concerned with shorts caused by the wiring), and timing to get it done before my trip, I took the easy way out and got ARB to do it!
    When I was there the ARB guy told me there was another Prado 150 there for second battery installation as well, except that the owner provided his own battery (another D34). I didn't know that was possible. The cost of the D34 from ARB was $395 + GST, BCDC1120 was $450 + GST.
    150 D4D VX, ARB Winch bar, Yoko Geolander G012, Warn XD9000, OME, ISI bike carrier, second battery with Redarc BCDC1220, Black Widow drawers with fridge slides.
    Re: ARB dual battery setup
    I had the same install done today except I also had a BAINTECH Flush Mount Single - DC 12 Volt LCD Meter added so I can keep and eye on the battery. Hopefully get to test it over easter up at Canarvon Gorge
    2012 150 Series Altitude, Crystal Pearl, Mickey Thompson STZ's, Toyota Carpet Floor Mats, Toyota Rubber Floor Mats, Toyota Cargo Rubber Mat, ARB 47L Fridge, Toyota Tow Bar, Rhino Sports Bars and Rack, ARB air compressor. Uniden UH076SX handheld UHF [i]Still to come: Bull bar, Spotties[/i]
      The meter is a good idea, I am thinking about adding one as well. A few times the fuse blew in my setup and I didn't get any warning until much later.
      Is your meter wired before or after the fuse, ie can you tell if the fuse blows?
        The meter is installed after the fuse so all it's telling me the battery voltage at the outlet
          Where abouts in Brisbane did you have yours done skip73?
          2014 Prado GXL, Silver, ARB bullbar, Old Man Emu, Safari snorkel, Rhino heavy duty bars, Electronic anti-rust, uhf, dual battery, dcdc charger, anderson plug, 3 x 3rd row cig plugs
