Adjusting Phone Mic Gain?
  • Adjusting Phone Mic Gain?
    Hi All,
    I have the 6 stacker Toyota stereo in the dash and the bluetooth phone connection sounds like **** to the caller on the other end. I have ruled out other phones and coverage issues, and when I spoke with Toyota, the told me I could adjust the mic gain. There is no reference to this in the manual and they were not very clear on how to do it.
    Any ideas?
    Cheers!
    P.S. As an alternative, am I able to connect an external mic (as opposed to the one in the head unit) and place that up near the drivers head?
    Anyone? Anyone?... Bueller?
    Im more interested in the external mic option now - has anyone had any experience with this?
    Cheers!
      I would start with these guys. Evidently they know how to adjust the gain.
      If you want to replace the mic, try talking to a car sound installer. They may give you some free advice, or not. Either way, you've lost nothing.
      Unless you want to replace the head unit, I'll hazard a guess that the solution will involve cutting and splicing wires on the mic-in line.
      Mike
        Try this
        NEW TSB - How to Adjust Bluetooth Mic Volume
        T-SB-0097-09 March 24, 2009
        Audio Bluetooth System Outgoing Call Volume
        Adjustment
        Service
        Category
        Audio/Visual/Telematics
        Section
        Cellular Communication Market USA
        Applicability
        YEAR(S) MODEL(S) ADDITIONAL INFORMATION
        2008 – 2009 Avalon, Highlander,
        Highlander HV,
        Sequoia, Sienna
        2007 – 2009 Camry, Camry HV,
        RAV4, Solara, Tundra
        2009 Matrix, Tacoma, Venza
        Introduction
        When using the audio bluetooth system some customers may mention that the outgoing call volume
        is too low or distorted. Please use the following procedure to adjust the outgoing call volume
        to address these conditions.
        Warranty Information
        OP CODE DESCRIPTION TIME OFP T1 T2
        N/A Not Applicable to Warranty – – – –
        Repair Procedure
        This procedure applies to vehicles equipped with the audio bluetooth system only.
        NOTE
        For vehicles equipped with the Toyota navigation system, please refer to the Repair Manual
        procedures.
        NOTE
        This entire procedure must be completed within 15 seconds from the time the ignition is turned on
        until you press the tune knob on the radio. Vehicle must have a phone previously paired to the
        system for this procedure to work.
        1. Turn ignition “ON”.
        2. Turn radio “OFF”.
        3. Turn ignition “OFF”.
        4. Turn ignition “ON”, and immediately start pressing the “off hook” button on the steering wheel
        until the radio displays the “Not Linked” or phone message.
        5. Immediately press the volume controls on the steering wheel: Vol. “UP” - Vol. “DOWN” (3 times).
        6. Press the tune knob on the radio once (display should read “Vol Type”).
        7. Turn the tune knob on the radio until the display reads “Send” volume, then press tune knob.
        NOTE
        Only choose “Send” volume, modifying other settings may cause poor performance of the
        Bluetooth system.
        8. If the customer is mentioning the outgoing call volume is too low, turn the volume knob to the
        right to increase outgoing call volume (+3 or +4 are recommended).
        9. If the customer is mentioning of distorted or clipping sound in the outgoing call then decrease
        outgoing call volume (-2 or -3 are reccommended).
        10. If Bluetooth system still has original customer issue after performing the adjustment, diagnose
        microphone circuit using the following repair manual instructions found on the Technical
        Information System (TIS).
        2011 GX TJM type 13, Airtec snorkel, TJM bash plates, Gensis HID lights & a few antenna's
          Thanks for that, I'll give it a go - although I don't have steering wheel controls. Hopefully it works!
          Cheers.
            How did you go without the steering wheel controls as I'm in the same boat and I can't work it out.
              Unfortunately as I have the GX, I don't have steering wheel controls, so I couldn't get it to work... Ideas?
