Radio operation
  • Radio operation
    Can the radio/CD be operated with the doors open with out the beeper going off continually?
    I don't believe so no.
    2011 150series GXL
      Press the start button TWICE (in manual) without the clutch in, this will go to powered accessories mode, and no beeps with the door open. Not sure how you do this in an auto.
        But that turns it to ON, as opposed to ACC. Which I wouldn't recommend as that means that all the electrics in the car are on, not just accessories.
        That is, I assume the same happens in both the auto and manual when you press the start button twice.
        wooley
        2011 150series GXL
          I have further investigated and it appears that the beeper only sounds when the driver's door is open. I also found that the radio turns off and the red light in the start button goes of f after 1 hour off opertaion. I assume this is a battery saving service, but as usual, cannot find any reference in the manual. Any comments????
