Anyone know where the fuse for the bloody door open chime on a 150 is?
Annoying door chime
Gday Tones120
Read this link below but make sure you read the whole thread as there is a few options
http://www.pradopoint.com/showthread...l=1#post286616
Hope this helps!
It doesn't have a separate fuse as far as I know. You'll have to cut the wire if it's making you that sad...
Just remember the door chime is different from the seat belts... Read above thread.Last edited by wooley; 10-12-2011, 10:21 PM.2011 150series GXL
Hi guys
If you opt for the 4mm x 12mm self tapper i would blunt the end of the self tapper so that it does not perforate the speaker so that if you want to sell the car at a later date you can remove the screw so that it works again if need be!
I believe if you use silicone you may immobilise the speaker indefinitely! (Always leave an option for the un-do
