Originally posted by daniel
View Post
Redarc dc -dc charger
Where did u mount this device... up near your main battery?[I]cheers..... Rob (macca)[/I]
[B][I][COLOR=Green]Car-2: 1993 Suzuki Vitara 4Dr (modified for Playing) [/COLOR][COLOR=#ff0000]Now Retired[/COLOR][COLOR=Green]
[/COLOR][/I][/B]
I installed mine up near the AUX battery, and so far it has been working great, I made sure cable size was adequate. If you are interested in photos of the install see by rig build page.2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
Hi Daniel,Originally posted by daniel View PostHi all
my dual battery setup
redarc bcdc1240 (40A Dc-Dc charger)
optima yellow top d34 55ah
ARB battery tray
4mm2 cable into the back for fridge rated at 10A
and a Anderson plug for solar
I've notice you intalled the dc-dc charger next to the battery.
According to the ARB shop here in Perth, that device is quite sensible to heat and stops working at 80 degrees (temperature value confirmed by data sheet).
He was suggesting to install the charger in front of the main radiator so that it doesn't get heted by the engine and get cooled by the air.
I was considering installing everything as you did, but then the heat issue set me off.
Did you ever notice any issue with heat so far?
Ciao
Marco
Hi All,
Also had worries about temp under bonnet but due to limited time before departure I mounted my BCDC1220 under bonnet on side panel next to brake plumbing. So far have not noticed any temperature effects. Charges Aux bat at about 20A and when it is charged puts about 17A plus to trailer battery (half length at 13 sqmm and half at 10sqmm. I believe it works much better than just connecting trailer to main battery.
Have checked output and case temp after prolonged high speed towing on current trip. (SA, NT and now WA). Output remains as rated and case temp after stopping and opening bonnet is only warm and definitely not hot.
My main complaint now is it is only 20A suspect 40A may be better to charge batteries on shorter trips.
When I have more time I will rethink it all. Maybe dedicated chargers for aux and trailer batteries.
Cheers2018 Prado 150 VX Auto
I saw the new 25Amp Redarc BCDC with Solar MPPT. Looks good. See here
http://redarc.com.au/static/files/BC...d_02052012.pdf
cheers[B]Robert
Really the only benefit i can think of this rather than the BCDC1240 is you can use a cheaper battery that cannot take the 40A charge rate.2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
I ran 13mm2 in car to Anderson socket. Camper trailer was made with 10mm2 from its Anderson socket to its batteries. Both runs are about 5metres.Originally posted by daniel View Posthi Prone
good to hear there is no problems
ddi you join a 10mm2 to a 13mm2 and if so why ?
this is true cheap batteries cannot handle being charged quickly. Especially AGM or sealed batteries. This was the reason i got the Lifeline AGM battery as it can take the charge. also optima batteries would also handle the current. Had to sell my left kidney as they are not cheap but worth it, hmm2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
Wouldn't the vehicle's alternator deliver more than 40amps to charge the battery? Aren't they an 80amps or similar? Obviously some amperage would be taken up to run the vehicle, lights etc.Originally posted by Kowolski View PostRedarc strongly advised me not to use a BCDC1240 with just one AUX battery. Told me they have had numerous events where the 1240 had damaged batteries in 4WDs where the AUX battery simply can't handle 40amps, or if it does initially after a while they don't cope.Winston.
