ARB battery tray - is there a difference between trays
  • ARB battery tray - is there a difference between trays
    All,
    Can someone let me know if there is a difference in the mounts for the SBI12 compared to the BCDC???
    I bought the BCDC seperately, but it appears I was sold the SBI12 ARB pack. I can see how the SBU12 would simply bolt onto this tray and bracket, so since the BCDC is different shape, I was wondering if the bracket setup is different.
    If anyone has used the ARB BCDC tray, could they please let me know...
    Regards
    I didn't think ARB had a different tray for the BCDC, Dave?
    All the installations I've seen use the SBI12 tray, and mount the BCDC to the guard or make up a bracket to attach it.
    2011 150series GXL
      I do not believe there is any different tray for BCDC. I made mine do suit the location I mounted the charger.
      2012 GX Prado 150 D4D Glacier White Auto with colour coded Rear Kaymar Tow bar Step, TJM T13 Bull bar, Safari snorkel, 100A Lifeline Battery, TJM battery tray, Redarc DC-DC 40A charger, 8" in dash GPS, Speedy Avalanche Wheels, Coopers 265/65 r17 AT3, AMTS Bash plates, TJM Side Steps, Ultimate Suspension 2" lift, Premier Winch.
        Downunder,
        Where di you mount the BCDC???
          Originally posted by sapradogxl View Post
          Downunder,
          Hi Dave,
          here is a pic of where I had my BCDC mounted. It is on the driver's side on a made up bracket, all going well so far.
          Mark
          [B]White D4D GXL auto Mickey Thompson ATZ 4 rib 265/70 R17, Genuine towbar, OME Suspension, ARB Sahara bar, Safari Snorkel, Icom 440N UHF, Rhino sportz bars, redarc BCDC1240 dual battery system, Drifta drawer setup, headlight upgrade.....more to come....[/B]
          My Rig Build [url]http://www.pradopoint.com/showthread.php?24451-Mark-s-White-D4D-GXL[/url]
            I mounted mine on the drivers side infront of the brake unit.
              Thanks Mark,
              I think it is back to the drawing board for me, and try to find a good spot like yourself to mount it.
                Just wondering if anyone could post photos of the ARB battery tray for the 150 (without a battery in it, I want to see the tray)?
                  Thanks Mark,
                  Why don't you just use an sbi12, Dave?
                  2011 150series GXL
                    Wooley,
                    I have, and going to use the BCDC for something else
                      Wooley,
                      Ahhh I see
                      2011 150series GXL
                        Hmmm, I believe I talked you out of the original plan for the BCDC and supervised your exemplitory installation work for the Sbi...
                          I do beleive you are correct Matthew
