Hi all! Have a Altitude with only 300km on it and still working out what everything does! Can someone please explain what the center diff lock does and when to use it? and whats the deal with the pollen filter button the the dash? Ive read the manual but still dont get it 100%. Thanks for any feed back!! Damo
Centre diff lock / pollen filter button
Polled filter button? I've never heard of a pollen filter button. Where is it?
As for centre diff lock, have a search, heaps of threads on it.
Some people use it as soon as they hit dirt, others use it when theyre doing a bit more serious 4wding. Personal preference.
Just don't use it on the black top.2011 150series GXL
Use it as an extra filter for the air for short periods of time, such as when you are driving past a fire to help with the smoke or through a paddock of flowers when you have an asthmatic in the car to reduce the pollen that comes into the car.Originally posted by GLXMAN View Postsorry wooley! its called Pollen removal mode button! Its says in the manual
"Outside air mode switches to recirculated air mode. Pollen is removed from the air and the air flows to the upper part of the body. Usally the system will turn off automatically after 3 minutes"
When do you use it?
Center diff lock - only when you have issues with traction. To help keep all the wheels spinning.
SteveStephen Bloomer
