Just thought, after adding my Redarc SDI12, I decided I ought to install an override switch so if the starting battery ever dies (Happened several times on my old Prado) then I can press a button on the dash and start off the AUX battery.
Quick trip to Jaycar secured me the parts required to complete the job.
1x Momentary Illuminated Switch
2m of 4 Core Silicon Sheathed Cable
1x 2m length of cable protector
1x 1K ohm resistor
The LED requires an earth so I picked this off (Black wire) from the earth on the Redarc unit. Saved trying to find an earth in the dash.
The blue wire is connected to the override connector and the brown wire is connected to the AUX battery side of the Redarc as per the diagram included with the unit.
Continued...........
1x 1K ohm resistor
