Hi all, looking for some advice on dual battery set up for my D4D 150 Prado. Planning on installing a Full River or similar 80AH 2nd battery. I have read through some threads but am a little confused. Can I use a standard ARB or Redarc isolator, I have also read that the standard alternator does not supply enough amps or is low voltage to charge two batteries via the traditional isolator type switch, however I have read that there are people using them and they work fine. If the alternator is low voltage, should I use the low voltage model like the Redarc BCDC 1225 LV.
I have been using the older regulator type isolator switch for years and which has performed sensationally, however the plastic case has seen better days so I need to replace with something either way.
2nd question. I am looking to install either an ARB orTJM bullbar soon. I have not used my factory fog lights in any vehicle in 20 years, so would rather not pay the additional $100 for a set to fit into the bullbar. Can I instead use the wiring to wire up a LED light bar, or LED spotlights. This would save me installing another wiring loom. I am not sure how the factory fog lights work with high beam, am yet to check this out.
Thanks in advance.
Thanks in advance.
