Has anyone had this problem, its intermittent and affects the right hand lights only.
150 Indicator Lights flashing fast
Blown bulb? Sorry meant dodgy bulb, change them side to side and see if the problem swaps sides.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Solution #1: only make left turns.Originally posted by getaway ray View Postaffects the right hand lights only.
Solution #2: don't use your indicators like 80% of the f*$kwits around here.
Solution #3: like has been said already, there'll be a bulb that stops working. In my experience, the little ones loose good earthing and quit working until you wiggle the bulb, clean it or replace it.Dave
