Horn not working - 2010 Prado 150
  • Horn not working - 2010 Prado 150
    Fuse is good. Toyota said switch (centre of steering wheel) is good. is there a relay i should check somewhere. horns are good. any help much appreciated
    If Toyota looked at it why didn't they fix it? Ran out of time?
    Cars are expensive, but not nearly as expensive as a woman
    Blake
      Toyota just had a quick look when they serviced it. need to book it in for auto elec to check wiring. just dont want to pay top dollar if its a relay or something
        There should be a relay for the horn in the cabin possibly near the ecu. The wiring diagram I have here is for a fj cruiser and that where it shows it's located so the 150 could be similar. Should be stamped toyota horn relay but don't quote me on that, it might just have a serial number .
        The road less travelled is definitely the best road to be on
          Thanks Shangus. will look there shortly
            I have the same problem. It's happened over the past week. I tried to replace a fuse which seemed to work for a while. Tonight I ran a wire from the battery to the horn to rule that out as a problem, as I thought horns work fine. (Jumped a bit... ). Was there a way Toyota checked the switch was good on the steering wheel.
            2007 GXL Prado V6, Charcoal, Sovereign Bull Bar, Tow Bar , Coopers STT 265x70x17", 2" OME Lift, Black Window twin drawer system w Fridge Slide. *** Written OFF ***
            2011 GXL Prado D4D - Blue Storm, Bonnet / Head light protectors, tint. ARB Delux winch bar, HR towbar, Blackwidow drawers, GME TX3440, Projecta 150AMP dual battery system, BFG AT 265x70x17", IPF900XS, Magnum 9000lb Winch, Hn5i navigator. 2" OME Suspension.
              Not sure if it's related, but my 2010 GX was recalled to have the spiral cord inside the steering wheel replaced, maybe check if your cars are part of that recall. It said is was related to the airbag, the wiring could rub through. It's probably a long shot, but worth a look,
              Cheers Brad
              [B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
