indicator and fog light wiring for bullbar.
  • indicator and fog light wiring for bullbar.
    Its probably on here already about 50 times. But I cant seem to find.
    im searching for the correct wires for the indicators and fog lights on my gx 150.
    any help / locations would be great.
    Nobody fitted there own bullbar by the looks.
      No, I had mine done..
      Sorry.
        Indicators are easy enough as they are still connected to indicators. Fog lights are usually taped up out of the way. You will need to put a fuse in the right place and do something about a switch. If you buy a GXL indicator stalk it is plug and play (at least that is what has been reported before) otherwise you will need to try and trace the wiring.
          In a early 150 GX the GXL indicator stalk needs to be put in, the plugs are just taped back near where the fogs should be. I can't remember for certain, I think either a relay or fuse is needed in the under bonnet fuse box and it all works sweet.
          Depends on the bullbar, some come with a plug and play loom for the indicators and park lights, if not just solder into the wiring at the back of the headlight. Use a test light to work out which wires you need. All pretty straight forward
          [LEFT]Silver 150 Facelift
