Wiring Diagram Map Lights Photo inc!
  • Wiring Diagram Map Lights Photo inc!
    Now I'm having trouble figuring out which cable is power so I can run my rear view vision reverse camera (wireless) I had it connected to the map light directly but the screen would only work when the map light was on. So I want to now tap into the cable directly but have no idea which colour cable that power is on. I've done heaps of searches and can't find any diagrams. Here's a photo
    Here's the photo sorry.
      Do you have a test light or a multi meter? Just check each wire until you find the one with power!
      Otherwise grab a workshop manual from your local auto store as they usually have wiring diagrams.
        Bugger shops are closed, what we are trying to achieve is the power is connected to the globes but when you close the doores it turns off so we won't in constant but don't know which wire it is as there are a few. So basically we won't it going to the wire that runs the globes but before the switch
          30 seconds with a test light and you should have your answer
