Cruise control stopped working
  • Cruise control stopped working
    my 2013 gx prado was having cc issues, the cc would only set if the wheel was slightly turned. This made it pretty dangerous to set at 110kph!!!!
    Now it won't set at all!!
    Any ideas? Have checked clutch and brake pedals, will check those sensors but am a little bemused???
    HELP
    Sounds like the spring loom in the steering wheel, pretty common issue for vehicles with cruise controls on the steering wheel. We had the spring in the missus Rav changed last year, it was doing almost exactly as you described until it died all together.
      As Above. you can try some contact cleaner on the rings.
        Wasn't there a recall on the clock springs for certain models?
          Yes, my 150GX has clock spring replaced under recall. It was something to do with the airbag potentially failing to deploy in an accident.
          If it hasnt been done, get it done. If it has been done, blame Toyota workshop for Cruise problem
