Wiring TX3100 UHF into 12v lighter in centre console
    Where did you end up mounting the UHF unit?
      I put mine like this:
      I tapped into the IGN wire for the stereo using the wiring harness I bought to install the Alpine.
      Cheers Brad
      [B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
        I hooked mine up to the constant power feed off the back of the stereo. The reason i did this is because you then need the ignition on keys in etc to use the cb. such a pain if you want the car off etc but still want to use the CB. But each to there own again.
        Cheers Joel
