Parker light wire
  • Parker light wire
    hi all what is the parker light wire im not sure what color it is to hook my switches up for illumination
    Pro tip... if you directly to the dimmer switch you will find it there. Plus you'll also find the negative dimmer which if used for the switches earth will adjust the brightness of the switches when you adjust the dashlights
