Originally posted by Skinny666
View Post
Switches similar to 150 Prado OEM
Purchased the ones from amts. They look just like they were factory options. Has anyone removed the center console and is there room for the switches and wiring harness supplied in the bays near the power plug and USB port?
How do I get into the console without breaking anything?
Plan to keep the places near the hi/ lo selector for elockers when we fit them.
Try this one http://www.pradopoint.com/showthread...or-ease-of-useOriginally posted by Skinny666 View PostPurchased the ones from amts. They look just like they were factory options. Has anyone removed the center console and is there room for the switches and wiring harness supplied in the bays near the power plug and USB port?
http://www.pradopoint.com/showthread...l=1#post275108Originally posted by Vasilako View PostJust on these switches, I have got one for the driving lights, but does anyone know which wire to tap into to make the light come on when your headlights come on? Wasn't sure which wire to tap into (e.g. off the headlight washer or Idle up switch)
Instructions seem to be for a 120/ pre facelift 150. I plan to put my driving light and light bar switches between the storage console and gear lever. E-Locker switches to go with the hi-lo selector, center diff lock and DAC switches.
Trying to add photos but not having any luck so far. Have been able to get the switches in place. Any suggestions as to how I can get into the center section to run the wiring etc?
Centre section as in behind the storage bin and a/c controls?
First yank on the a/c controls, they are cliped in, then the two black strips down either side clip off to reveal bolts/screws holding everything else in. Work your way down the stack taking bits out, easy done.[LEFT]Silver 150 Facelift
Between the seats is the arm rest, forward of that is the USB, Audio connection and power socket. Just forward of them are 2 blanks, this is where I am fitting the switches. Need to connect to light power, probably from the transmission shift lever lights hence needing to take the center console out. Posting a picture would be so much easier for all to understand where I'm talking about.
Try this one - not comprehensive.Originally posted by Skinny666 View PostBetween the seats is the arm rest, forward of that is the USB, Audio connection and power socket. Just forward of them are 2 blanks, this is where I am fitting the switches. Need to connect to light power, probably from the transmission shift lever lights hence needing to take the center console out. Posting a picture would be so much easier for all to understand where I'm talking about.
read a few posts down for some hints.
http://www.pradopoint.com/showthread...l=1#post311322
Thanks for the guidance with this. Removing the first piece was nerve wracking, worrying that I would break something like the ham fisted git I usually am.
Next step is to make the wiring harness for the light bar and Cibie Oscar pencil beam lights. Off to search for getting the trigger from high beam for the relays. Trying to make the harness so there is no change to the original wiring. Guess I just make things harder for myself than they need to be.
