Redarc Tow Pro wiring 150 series
  • Redarc Tow Pro wiring 150 series
    Hi hoping for some advice on wiring up the Tow Pro! RedArc are a bit shy on component supply! My questions are-
    1-how do i locate the correct (colour) wire to the trailer brakes ( I have a 7 pin flat trailer plug fitted by ARB) and
    2-where is the wire i am to connect to for the vehicle brake lights (is it at the rear wire lume behind the brake light?)
    It looks like I have to splice Red cable into an active brake light wire?? I'll try and find a photo of their wiring diagram. regards and thanks for the advice in advance...crano
      It should be the blue wire in the trailer wiring, the factory loom runs up inside the rear of the vehicle on the passengers side, the blue wire sticks out here just before the trailer control module for you to join into. For the brake light wire you have two options, first is down at the switch on the brake pedal, the other is at the light down the back. Either way is fine on the 150, just be aware you can't connect at the pedal on all vehicles due to complex electrical wizardry not liking this. Remember to use the appropriate sized wire and an appropriate sized auto reset circuit breaker.
      [LEFT]Silver 150 Facelift
        Andy, thats very good advice. Thank you! crano
          Is there anywhere on the "trailer control module" that you can pick up the brake signal? It should be there... and it's nice and close to the blue wire for the brakes. I was thinking of putting the Tow Pro in the back of the car and running an ethernet cable up the front for the knob.
            But then you have to run power to the back, as I believe you HAVE to run the power off the main battery not the aux.
              Correct, and also through a self-resetting circuit breaker. Aux batteries can run flat leaving you with no trailer brakes.
              [SIZE=1]Cheers Jim.
              [/SIZE][COLOR=#0000cd]
                I haven't towed with my 150 yet, but my tow pro I mounted under my centre console and the knob is next to the diff lock button. For the brake I spliced the wire at the pedal switch, have got a 25amp wire all the way to the plug as the Toyota one isn't 25 amp and put a new plug on
