Hi Ya'll
I have just purchased a Tigerz11 roof rack (reasons behind this selection is I'm more tempted to hack up a $400 piece of kit then a $$$$ ARB one so no banter! I Will be modifying this to accommodate the 'moon roof' in my Kakadu) I have a 50" curved bar to mount on the front and 2 x 4" LED bar's on the rear.
What are people suggestions on how to run the cabling up to the rack?. The Curved bar has Spot & Flood and the 2 rear will be run in parallel, so at minimum i will be running 2 switched circuits? im not sure how the spot and flood will work if they can be switched separately..
Another thought i had was to run a main up to a distribution box from the auxiliary battery to house relays and power junctions and then run the switch wires back down?
Open to ideas and suggestions
TIA - Mikey J.
TIA - Mikey J.
