Ignition on new 2015 GXL
  • Ignition on new 2015 GXL
    Hi
    I know in the "wiring" section is says that the pink wire is ignition, but is this still correct on a new 2015 GXL?
    I finally found a pink wire in the wiring loom, but after some tests there was no 12V when the engine was running.
    Any suggestions? as I'm currently installing a Amelec DCC pro battery system and ARB onboard compressor.
    thanks
    Sorry Andrew I don't have the answer but it looks like there might be another pink wire deeper in the loom that I can see. Maybe it's that one.
      going through the 'wiring' thread again, it seems a grey wire my be useful....
        No ignition source in the fuse box?
          really hard to get too.
          I used the grey wire from the heater relay box
