Trailer Lights
Can you get the Toyota trailer module? It plugs in and is a repeater.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
In Australia that connector plugs into a small black box which connects to the trailer wiring. I'm pretty sure it's the same worldwide - if you look at the European instructions for installing the tow bar wiring their setup is the same.
The trailer wiring is connected via a "repeater box" which isolates the car wiring from the trailer a bit - that way if you short out the trailer wiring you don't blow up the car lights.
One Australian seller of the module is here but they don't sell outside Australia.
