G'day all.
This may end up being a follow on to my thread regarding my optima battery, or may be a separate issue.
Tonight I checked my battery voltages, car had been sitting there for 9 hours without being driven, no fridges or aux stuff running off the batteries. Main battery was 12.35V and aux battery was 12.58.
Main battery is a Century heavy duty approximately 8 months old and the aux is an Amaron which is less than a week old.
The car starts fine and doesn't seem to crank slowly at all. My multimeter seems to be accurate as I have a permanent voltage gauge connected to my aux battery and that was reading 12.6 (only reads to 1 decimal place). The water levels in both batteries are ok.
Can anyone think of what might cause this?
About 1 week ago I installed a voltage booster (Piranah Alternator Output Compensator) but even prior to that I had noted sometimes that my main battery would be on the lower end of voltage.
For the last few months the car has done trips of maximum 30 minutes (usually runs for 10 mins, twice a day to/from work)
Cheers.
Cheers.
