Steering Wheel Zero Calibration, How to?
  • Steering Wheel Zero Calibration, How to?
    Hi All,
    My Cruise control suddenly stopped working and after some searching, I found my spiral cable was the problem.
    I ordered online and replaced it today. The cruise control if fixed but now I am stuck with ERROR code C1433.
    I believe I need to do a steering wheel calibration, has anybody done this before and can please offer some help.
    Prado 150 GX
    2012
    Diesel.
    First post on PP by the way
    Did you unplug the steering wheel sensor?
    Did you turn the slotted disc whilst you had spiral cable out?
    None of the above needed to happen for a spiral cable change. And if it did probably caused your problem.
    You could try resetting the error code to see if it clears it. If it returns then you've got more to do.
      Hi there Piggy,
      I am in a similar scenario and would really appreciate your advice. What is the more you mention?
      I removed my steering wheel to slightly adjust the angle, and this resulted in the skid and power steering errors after the shift. I then totally removed the clock spring and spiral sensor unit to see if that was the issue. (The warning to not remove from the cable is underneath and not visible when removing )
      It does not appear damaged and all steering buttons still work and am hoping this just requires recalibration.
        You should have success with any wheel alignment shop, give your local a call to see if they have a Snap On or similar diagnostics tool.
        My 150 was returned after a wheel alignment with this error code, stupid buggers plugged their machine in, did the alignment and then couldn't clear it.
        Their only advice take it to Toyota! Talk about amateurs.
        Luckily car was booked in to 1KD in Bundy for an ecu tweak and he reset it in nothing flat.
