My ARB air compressor ( under bonnet mounted thanks to AMTS mounting bracket) has suddenly started to blow the inline 30amp fuse. I used it to pump up my Fathers in laws spare tyre a month ago and it blew half way through ( blessing in disguise really could have been in the middle of nowhere ) and since replacing the 30 amp fuse its blown two more times. Anyone experience this before or know what would be causing this symptom? Is my little old ARB compressor finally cactus? It would have to be at least ten years old.
Last electrical thing touched on the car was a Redarc brake controller and that was 3 years ago so its not like i can blame myself for fiddling with it.
I noticed the blue light is out on the switch that turns on the compressor as well. -is there some sort fo inline fuse around that might have blow and is causing the issue?
Cheer smokey
Cheer smokey
