Hi All
Wondering what people have done regarding powering their caravan fridge.
In my Pajero I ran cable from Aux battery to the 12 pin plug at the rear and hooked that up to caravan to run 3 way fridge...never had a problem as this was just charged via VSR
In the new Prado i have a BCDC 1225d i installed to charge Aux battery.
Going to run a wire to the 12 pin to run the caravan fridge
Not sure i should run it from the Aux battery as the BCDC will only push out 25 amps.....3 way may draw 15 amps or so......so still should be enough
Or run it from the main battery which is getting 140 amps or so from the alternator
What have others done?
