Re: DC to DC Chargers
And sorry Damain, but you are a perfect example of being focussed on a single solution and you are also proof that the biased misleading advertising used to flog these DC-DC devices is working.
Some facts on just one of many options available.
For far less capital outlay you could simple add a second battery.
Even using the same amount of capacity as you would with your DC-DC set would mean discharging the two batteries to only half that needed for your DC-DC set, which means your battery has to be worked twice as hard, which in turn means a shorter life for your single battery set up.
Because the two battery set up is only discharged to half the depth your DC-DC set up discharges your single battery to, the two battery set up will be charged in a shorter time than your DC-DC set can.
Again, because you have two batteries, you are only drawing half as much current from each battery and the lower the current draw, the easier it is on each battery, so again, the longer the batteries will last over your single battery.
There is also the obvious advantage of the two battery set up, you have heaps more power available if you need it.
Whereas with your DC-DC single battery set up, if you find you need more power than you have available, you have only one option and thats to add another battery ( more additional costs ) and the instant to you add a second battery to a DC-DC set, you also have to factor in up to 90% more driving time ( again more additional costs ) to allow your current limited DC-DC device time to charge your two batteries.
I am not against the DC-DC devices, there are some situations where they can offer some advantages, it the way they are marketed that is the problem, using grossly misleading advertising hype.
And Damian, as you can see, there are far cheaper, more effective ways to achieve better results than these devices can do, so before you accuse others of being single minded, you need to do some homework about your own ideas.
Matty80
