Found - 150 wiring diagram and other info
  • Found - 150 wiring diagram and other info
    If people are looking for the 150 series wiring diagrams they are available from this site:
    http://www.toyota-tech.eu
    Go to the "Repair" tab and look in the "Payable Access" column.
    There is a bunch of other info available such as wiring harness, location of equipment in the engine bay, location of equipment items in the dash, repair manuals, instructions for removal and replacement of components (e.g. rear bumper, roof lining, front console), etc.
    To access these payable items you have to become a member and then pay for access - but you can pay for 1hour access only, several hours, days, a year, etc. It only cost me 3 Euro for 1 hours access and in that time I was able to find and download all the wiring diagrams for my vehicle (they are .pdf files) as well as other miscellaneous info.
    Ando
    2010 GX Turbo Diesel
    Re: Found - 150 wiring diagram and other info
    Can you post up some of the diagrams as I still need to wire up my ARB air compressor and can not find a power supply of it.
    The cab/dash would be great.
    150 Prado D4D GXL Blue Storm, T13 TJM Bar, 265/70/17 Goodyear MTR Kevlar, Tigers11 1200 pound 2 speed Winch, Fox Shocks remote resevor, Air tec Snorkel, ARB Air Lockers Front and Back, Off Road Systems Draws with Drop Down Fridge Slide, Wetsuit seatcovers.
      PM sent
        Just a reminder on the rules guys and info from said Toyota-tech site:
        Copyright, industrial property and intellectual property notice
        The presentation and all content of this site are protected by industrial and intellectual property rights. You may only use the information, text, pictures or graphics contained in this site for your personal, non-commercial use and may not reproduce, modify, transmit, license or publish it, in whole or in part, for any purpose without the prior written consent of TME, unless for viewing.
          Yes, I won't be posting the files and I have provided directions for people to get them legally themselves.
            Had a go at getting wiring diagrams for 2011 Prado KDJ150 using the link posted above(toyota-tech), but could only get correction bulletins, no main wiring diagrams.
            So not sure if the site is not up to date or they've taken some info off?
            Has anyone else been able to get them for the 150 series prado?
              Andoland, thanks for that....just downloaded a stack of wiring diagrams for my 2011 GXL.
              2011 KDJ150 Prado GXL D4D: Genuine bullbar & towbar, ARB dual battery system with REDARC isolator and REDARC EBRH brake controller, Lightforce 170 Striker HID spotties, GME TX3440 UHF, Safari Snorkel, EvaKool 45L fridge/freezer and twin headrest master/slave DVD/media players. (SARMAJOR heavy duty off road Trekker Camper Trailer on its way!!)
                WOW! $480 for a wiring diagram
                  Must have changed since I started this thread. As I said originally, for a few bucks I was able to download everything I needed.
                    There are online subscriptions options including one for only an hour, it gives you access to everything as far as I can tell. I signed up and had a look around and it's definitely worth paying for an hour or two to get the accurate info you need.
                    [B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
                      Thanks for all this info. I am going to pay the 3 Euro and get these files as well, but I have a few questions.
                      - What manuals should I get to show the locations of the wiring and wire colours?
                      - Is there one that shows how to pull the panels off to access the wiring?
                      - Are the files protected so that they expire after a certain time, or once downloaded I will be able to save and use as much and as often as I want for my own purposes?
                      Mark
                        As posted in other threads there is a Toyota Australia site were you can download manuals for a fee and get accessory instructions for free. toyotamanuals.com.au/
                          all the diagrams you could need $10... http://www.ebay.com.au/itm/TOYOTA-PR...EAAOSwN81WDM0c
                            Got that. Took a while to get it to display. If I recall, it will only work with 32 bit Internet Explorer. I have a 64 bit operating system and so 64 bit IE is the default. There is also a 32 bit version hidden away with 64 bit Windows and, so, you have to point the disc to where it is so it will open / browse properly.
                            There may have been a few tweaks necessary for the 32 bit version of IE as well (compatability?) but just can't remember.
