Cruising Range to Zero ? Diesel
  • Cruising Range to Zero ? Diesel
    Having had the Prado for 4 months now and planning on the Cape York trip around mid July I thought about finding out how many kilometres was left to MT after the cruising range indicated zero. Averaging 10.9 litres/100KLMs
    So filled the 5 litre tin up,put in the rear and waited to zero indication, set the trip meter to zero and drove around till MT. After 175 KLM prado stops 8)
    Put the 5 litres in and off to servo no problems.
    After 123 litres indication of full tank. Wait 1 minute,fill 1 litre,wait fill :x and so on. After 15 minutes showing 144 litres added. :roll: (Note: next service fault report to dealer) Not sure if anyone else has had this problem but if you are thinking you have 150 litres in tank and doing the long trip you could be caught out. Also based on the 175KLM travelled 15/17 litres would be left after Cruising range indicates zero.
    Past vehicles i have owned have had range of 40 - 60 klms after zero so quite a bit of margin on the prado.
    2010 Kakudu D4D,Crystal Pearl,TJM Alloy Bar,Snorkel,Brown Davis Underbody Guards,Icom UHF,Redarc with Dual Battery,Tigerz 11 12000lb winch,Custom Rear Storage,Rhino Alloy Platform Rack,50lt Boab H2oTank.Side Awning,Rooftop Tent.
    Re: Cruising Range to Zero ? Diesel
    You ran your D4D out of fuel :!: :?: :shock:
    Here's a quote from another thread: viewtopic.php?f=12&t=41&start=180&st=0&sk=t&sd=a
    Originally posted by Mark Smith
    Hi Guys
    Just a word of warning about running your engines out of fuel. Last time I did this it led to some dramas due to crap getting sucked up from the bottom of the tank. Long story short, I needed a new fuel filter and a reset of the ECU to clear the fault code that had caused "limp home mode". Luckily no damage done to the fuel pump. This was with a 1KZ-TE 90 series. I would be petrified about running a D4D out of fuel given the sensitivity of their common rail fuel delivery system. Be carefull!
      Was that 144 including the 5 you put into the tank after running out?
      Otherwise it would be 149 - pretty close.
        144 litres @ servo & 5 Litres from tin .
        Regards
        Rayd
          I always love the comments about "it picked up crap from the bottom of the tank because I ran out of fuel" Like the pickup isn't always at the bottom of the tank :lol:
          Alan
          [color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
