I have been hearing this god almightly rattle come from my standard exhaust and when I take it to Allan at Blitz custom exhaust (Hoppers Crossing, VIC) it goes away. when it does it, if i get a block of wood and push on the rattle from the cat goes away. Mind you its only done 66000 ks and failed already. For the record its never been hit or bashed, the mrs thrashes it i recon!!! So next week ive got it booked in for new high flow cat 100-200 cpi not sure which until the day and a straight through muffler. He did the high flow muffler on my 07 D4d hilux for $150 and made a big difference. turbo spooled up ealier and more torque. So ill keep you posted on the out come and total cost for cat, muffler and labour for guys interested in melbourne.
Exhaust systems for 150's which is best?
2009 Prado Kakadu 3.0L Turbo Diesel, ARB Deluxe winch bar, Safari snorkel, Chip It Performance Module, EGT Controller, Throttle Controller, Manta 3" SS exhaust System, Pro-Vent oil Catch can, Lightforce 170mm Strikers 75w HID, Waeco 50L DZ fridge, GME TX3540 & AE4705, dual battery, Many options & upgrades to come...
Originally posted by MNK View PostI have been hearing this god almightly rattle come from my standard exhaust and when I take it to Allan at Blitz custom exhaust (Hoppers Crossing, VIC) it goes away. when it does it, if i get a block of wood and push on the rattle from the cat goes away. Mind you its only done 66000 ks and failed already. For the record its never been hit or bashed, the mrs thrashes it i recon!!! So next week ive got it booked in for new high flow cat 100-200 cpi not sure which until the day and a straight through muffler. He did the high flow muffler on my 07 D4d hilux for $150 and made a big difference. turbo spooled up ealier and more torque. So ill keep you posted on the out come and total cost for cat, muffler and labour for guys interested in melbourne.
What was the result of the cat change MNK ?[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
I have not done anything about the exhaust yet as I found the noisy rattle I was getting was due to the bolts with the springs on the flange joint not doing up enough as there was not enough threaded section. Swap the bolts over and all good. This has not made me so pressed to go in and get it changed over too.
I have just ordered today a Chip It chip, egt controller, throttle controller, & oil catch can so I will be doing something very soon as ill be itching for the exhaust mod. To be honest ive been thinking to go full exhaust due to the fact that regardless I will need the dump pipe modified for the EGT controller sensor.
The Prado's biggest power robbing factor is the muffler, cat, and dump pipe. The pipe size is not the issue.
Change to high flow muffler and 100cpi cat for best bang for buck is my answer.
I now have to way up if the muffler cat & dump pipe made bigger with 1/8 gas bung & labour is worth doing comparied to a full system. ill be seeing Allan next week and keep you updated on his cost and thougths2009 Prado Kakadu 3.0L Turbo Diesel, ARB Deluxe winch bar, Safari snorkel, Chip It Performance Module, EGT Controller, Throttle Controller, Manta 3" SS exhaust System, Pro-Vent oil Catch can, Lightforce 170mm Strikers 75w HID, Waeco 50L DZ fridge, GME TX3540 & AE4705, dual battery, Many options & upgrades to come...
just got a lukey muffler cut and welded onto my prado.
car definately drives different, it's a lot smoother and better response at low revs.
no drone at all, but you can hear it's there and a bit of turbo whistle.
fuel economy on dash has dropped by 1-1.2 L/100 straight away.
any WA pper's PM for details.
cheers2012 150 | GXL | D4D | Auto | Graphite | TJM T13 | X-Ray 220 HID | Genuine Towbar | Engel 40L
I'm getting a straight through muffler fitted to the Prado next week. I've been quoted ~$250 which is ok for a standard muffler or ~$500 for a stainless steel version. Most of your quotes are cheaper than that. Am I getting ripped off for it? Or are the stainless ones that much more expensive?
Cheers.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Just get a standard one, it shall serve you well..[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][/CENTER]
Will the standard one rust out quicker? We spend a bit of time on the beach...Last edited by cbm8880; 02-06-2013, 09:11 AM.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Double post..........Last edited by cbm8880; 02-06-2013, 09:11 AM.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Hello guys, I have read through this thread and have some questions
150 related)
1: How many mufflers do the GXL's have? I have a GX and I only see a cat and the large muffler forward of the diff.
2: When you are talking about putting in a straight through muffler are you changing the large one just before the diff?
The factory GX system looks pretty good, the dump is smooth and the whole system is a good size, the large muffler there is huge though!
Mine is manual and I would not like to lose any boost between gear changes. I won't be chipping it, just a few easy killerwasps would be good and there seems to be an improvement in fuel economy by changing the muffler which is more appealing than power.
3'' would be too large IMO and just louder...
Cheers BradLast edited by ttmx83; 16-06-2013, 10:14 PM.[B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
Mine is a GX too. They replaced the large muffler you refer to with a 22" manga flow free flow stainless muffler. My "seat of the pants" tells me there may be a slight improvement in power, but I haven't yet travelled far enough to assess the fuel economy benefits. I'll post back after 3 tanks.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
Hey Jayden,Originally posted by jayden82 View Postjust got a lukey muffler cut and welded onto my prado.
cheers
Did you just do the muffler in the end, or did you opt for hi-flow cat?
Who did you goto and what did it cost?
Kevin
Hey cbm8880,Originally posted by cbm8880 View PostMine is a GX too. They replaced the large muffler you refer to with a 22" manga flow free flow stainless muffler. My "seat of the pants" tells me there may be a slight improvement in power, but I haven't yet travelled far enough to assess the fuel economy benefits. I'll post back after 3 tanks.
Any news on fuel economy?
I rang a couple of places today (close to home), they were all too busy trying to flog me a full system whenever I asked about muffler + cat replacement......
At $1300 fitted, I think I'll run with the high flow muffler first. From there I might consider cat. The money saved would be better on a snorkel (IMO)
Anyone end up changing their cat a few weeks / month after the muffler? If so, was it actually worth the cost or not?
Kevin
Sadly, I've not noticed any improvement in fuel economy. There is a slight improvement in power I think though. Overall, it probably wasn't towrth the investment to do this alone.
Sounds good though!2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
My car is approaching the 100,000klm mark, would something to consider be the lifespan of the catalytic converter? I still want to change out the big muffler one day but I reckon the difference wouldn't be as noticeable if the cat was reaching the end of it's life. I'm uneducated on diesel catalytic converters, but if they are similar or the same as those found on a petrol engine, 100,000klm can see them starting to block up.
In the end it might be just as cheap or easy to replace the whole system..... Which I don't want to do. (I'm a sucker for the cheap mods!)
Any thoughts on this?
Cheers Brad.[B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
