Supercar Performance module
  • Supercar Performance module
    Has anyone used a supercar performance module? A few guys at work are convinced this is the one to have.
    As I'm having issues with the chip I bought, I though I would investigate others.
    Any thoughts?
    Sean
    2011 VX T/D auto pearl white, 3" exhaust and [COLOR="#FF0000"]CHIP IT [/COLOR]module and Auber EGT gauge. Daul battery fitted cig and engel plug in cargo area and charge wires run for the camper. Dual DVD headrests and Extinx GPS/DVD unit. ScangaugeII.
    Never heard of it, have you got a link?
      Just another pulse width modulation style chip like the steinbauer
        Yes Barry , but thoughts ?
        Ryzz,
        http://scarparts.3dcartstores.com/Di...nce_ep_41.html
          No it's not.
          Yes it modifies injector opening time, but it also uses a predictive algorithm to adjust timing and controls boost. Quite a bit different to the Stienbauer which just increases the injector signal duration.
          Leachy.
          leachy_9
          EX-Prado Owner
            Originally posted by leachy_9 View Post
            No it's not.
            Leachy.
            Leachy is correct.
            These modules work by altering when the injector fires, how long it stays open for and how far the pin opens. Combining this with boost really gives us an edge on the Market and gives you genuine fuel savings along with more power! This is a really safe way as we do not push the car into extremes it was never engineered to handle.
            They also hold 4 different tunes which are programed entirely different for different situations and we can program them how ever you wish.
            Typically speaking we see gains of about 20-25% in power and torque at the wheels and about 15-25% in economy. The economy really depends on your driving style and what other modifications you've done to the car.
            Where abouts are you located sbclover? our head office is in Mackay we might be able to organize a Trial set up for you so you can have it fitted to your car and go for a drive to feel the power gains before purchasing it.
            Adam
            [SIZE=5][COLOR="#00FF00"]Diesel Smart[/COLOR][/SIZE] [SIZE=5][COLOR="#FF0000"]"Excellence In Diesel Performance"[/COLOR][/SIZE]
            Website: [url]www.supercarperformance.com.au[/url] phone: 1300 UPGRADE or 0749 530040 email: [email][email protected][/email] youtube: [url]www.youtube.com/user/SupercarPerformance[/url] facebook: [url]https://www.facebook.com/SupercarPerformance[/url]
              Hi Adam,
              I am in Clermont and rarely come to mackay but if the deal was right I would come over and give it whirl. I would just hope that it wouldn't give me the hassles that the first chip did.
              I will pm you my number to have a chat.
              Sean
                I would love input into the difference between this product and Chipit. They both seem like great products. Are they completely different? The Same? Similar but different?. Any input would be great.
                Many thanks,
                Keepingitreal
                [url=http://www.postimage.org/image.php?v=aVeJ4P0][img]http://null.postimage.org/aVeJ4P0.jpg[/img][/url]
                  Hey Sunwal072
                  I'm not going to comment on how ChipIt products, but what I can say is they're completely different. They alter rail pressures - we don't.
                  Our module plugs into the injectors along with the map sensor. They hold 4 tunes and the tunes are changeable from inside of the car. The different tunes are not just simply more or less fuel but we actually run different boost settings, different injection timing, pulse widths and a number of other things between the tunes. They are designed how you want them to work. The reason behind this is it's like buying 4 in 1. You can basically have a different module for 4 different applications, your daily driver, your towing tune, a 4x4 tune and a fun tune if you wanna race offroad or something of the likes.
                  Another good point of our module is our EGT Defence system which can be optioned with it. This can actually de-tune our module if you see high EGT's also with our LCD EGT Display you can train yourself to be a better driver when towing - lower egt's = better fuel economy.
                  If you would like me to answer any more questions please feel free to ask them and I'll do my best to answer them for all to see, otherwise if you want to PM me your number I'll get the owner of DieselSmart to give you a call and talk to you about our products.
                  Adam
                    So is it like a Steinbauer but even better?
                      Hi Sunwal
                      it plugs onto the injectors similar to a SB but it alters more parameters along with controlling the boost
                        I think I will come in and have a more in depth chat with you and maybe a test of this unit. I had a short chat about 10 months back while getting my windows done at your shop. Since then I have done quite a bit of research on chips and modules and I like the flexability of your unit. And I'm just down the road too!
                          hahah well if you want to come in today I will gladly get one ready for you to test drive should take about 30 minutes of your time. Mike and myself always love to have a chat to guys like yourself who want to come in, and since you've had your windows done by the other part of our shop here we can look after you with fitting maybe throw in some free dyno time
                            If you want, we could get it on the dyno this afternoon and do a before and after for you to show you what the module is capable of
                              NOOOOOO! Bugga! I took off this morning and only got your reply late this arvo! Had stuff all to do today as well? Unfortunatly I have to go back to work saturday so I will call in when I get back.
