Engine upgrade
    Originally posted by QUICKY View Post
    A V6 diesel is my dream Prado complete with 3t towing capacity but that isn't about to happen as it will take too many sales away from the 200.The 200 is dearer but you sure can drive them for a bargain. Also have a look at the spec sheet for a size comparison it may surprise you. The 200 is only 15mm higher 20mm longer (prado has wheel on back door) but is 85mm wider and this makes it look so much bigger than the Prado,but they sure have got a lot of room inside
    Quicky
    So Quicky, you getting the 200 series GX are you?
      Spot on AJ
      Add an L to it (GXL)
      This is what it will look like once I take to it
      We needed the extra towing capaciity and the extra grunt wont go astray either
      Was less than 10k more than an Altitude Prado
      Quicky
        Nice one Quicky, make sure you get it lifted early in the build. A mate of mine just bought the GX and that spare tyre hanging underneath is like an anchor!
        I can well imagine the extra grunt would help with your little van
