Originally posted by Woopi Warrior
View Post
The current GD Prado has a recommended fuel filter change interval of every 40,000km under "normal" conditions (which arguably just don't exist), and for it to be changed every 20,000 km under adverse** conditions...like towing, or driving in dust, or driving off road, or driving long distances, or driving short distances, or driving in hot, or driving in the cold...below is a quote from the service manual for the definition of adverse conditions, in which case the fuel filter should be changed at 20,000km).
I also drain the main fuel filer (its quick and easy) every 5,000km just to be sure.
** Additional service requirements when driving under adverse conditions, which could include any or all of the following:
Driving on rough, muddy or snow melted roads.
Driving on dusty roads
Towing trailers, caravans or boats, or using a car top carrier
Repeated short trips, less than 8km, in freezing conditions
Extensive idling and or low speed driving for long distances, such as taxis, couriers etc
Continuous high speed driving (at speeds over 140km/hr) for over 2 hrs
Using fuel from above ground tanks
If you drive in any of the above conditions Toyota recommend a fuel filter change every 20,000 km.
