KDJ150 Radiator Dimensions
  • KDJ150 Radiator Dimensions
    Can someone give me the dimensions of the 150 radiator?
    I have managed to source a 150 intercooler and im going to try fit it to my 120. Looks like ill need the 150 radiator also to make it work as the 120 radiator is significantly wider.
    Pete
    You wont do any damage by running a radiator that if smaller wont hold the coolant capacity required to keep every thing nice and cool ?? then your going to place an intercooler in front of it also restricting airflow ??......Must be plenty of other intercoolers around that would fit where you want it too ??.....Cheers Steve
      You wont do any damage by running a radiator that if smaller wont hold the coolant capacity required to keep every thing nice and cool ?? then your going to place an intercooler in front of it also restricting airflow ??......Must be plenty of other intercoolers that would fit where you want it too ??.....Cheers Steve
      It appears that the 150 radiator is narrower than the 120, deliberately done i assume so that the intercooler pipe work can pass around it. The 150 radiator does look taller than the 150 though, so im guessing the two would have a similar surface area and as a result a similar volume of coolant that runs through them. I dont see why Toyota would make a smaller radiator for the now heavier vehicle.
      If toyota runs this intercooler in front of its radiator in the 150 from factory, i cant see why it would be an issue in the 120 with the exact same engine(or close enough to it). The issue with front mounting an intercooler in the 120 is having the clearance to run the pipe work around the original radiator, without hacking up the radiator supports to much. Toyota overcame this by making the radiator not as wide and mounting the intercooler directly in front of it. Hence why im after a 150 radiator but i need to check the height to make sure its not to tall.
      Pete
