timing belt light
  • timing belt light
    Hi Guys,
    Is there an easy way to turn off the timing belt warning light after replacing the belt.
    Had mechanic do belt at 145,000 before I headed off across the Nullarbor not knowing how long I was going away.
    Now at 150,000 warning light on, do I need to see my local dealer, is it done through the computer?
    Terry
    Next time try the search button.
    I did I came up with this
    http://www.pradopoint.com/showthread...ing+belt+light
      Mines a 150 with key less start, tried following instructions but couldn't get to T-Belt mode.
      Will drop into City Toyota tomorrow and ask, they did computer update free of charge, usually very obliging.
        150 ohh ok, maybe put the details in your signature.
        So then when u ask, peeps can help more accurately.
        I can't remember if I Have done a belt in a 150 yet, I think it's the same procedure.
        It can be a pita doing these things with the push button sh!!ter.
        Not sure sorry.
          I had mine done at 125,000 because of water pump and other issues. I raised this with the mechanic and he just said bring it back when it comes on and he will fix. My next service is in about 6 weeks (130,000) and don't expect to need a reset for another 18 months as I normally do about 15,000 kms a year.
          Terry
          Canberra
            From the workshop manual, see page 2 or 3
            http://www.keepandshare.com/doc/7416...t-pdf-58k?da=y
            Let us know if it works as I haven't done the km's.......yet
              Yes thanks,
              Before reading your posting I saw City Toyota, they wouldn't do it till I returned with an invoice to prove belt had been changed.
              Saw my mechanic today he rang his mate at Toyota and did exactly as described worked perfectly.
              Mine a GX 150
              Regards
              Terry
