Hi all, I recently had a Steinbauer chip fitted and the improvement in power etc very noticeable car goes great. Am now looking at upgrading the exhaust and cannot undecided between the Taipan and Beaudesert. Fundamentally I am seeking any advice on who I could get to install and at the same time have the car dyno tuned. Am in Sydney on the south side so any recommendations would be appreciated.
Steinbauer chip and new exhaust
I went with the Beaudesrt and fitted it myself in the garage - my advice "get someone else to do it" getting the tail pipe over the diff was a nightmare.
I had a look at most of the systems and noticed that many were 3" except for the bend over the diff which was either 2.75" or flattened out to clear the heat shields with limited room in this space. Something to consider.
Very happy with the Beaudesert system, great service arrived in less than a week to the other side of the country. Every thing supplied and apart from getting it over the diff and removing the nuts from the turbo, went together very well.Kev,
I have both the Beaudesert 2.75 exhaust and the upgrade software Steinbauer on my facelift 150, fitted the exhaust myself (on a hoist) took about 2 hours, the hardest part was removing the factory dump from the turbo. Can imagine it would be very difficult at ground level
The Beaudesert would have to be one of the best fitting exhaust I have fitted/seen
They complement each other, the car is so much smoother and the torque increase is great
I have not had it tuned on the dyno yet as I only got the Steinbauer last week and have gone off on holidays (it is on the factory setting at the moment) I plan on getting it tuned in the next few months
Originally posted by rayp View PostThanks all for your comments..and thanks Kev7762 will take your advice on that as I don't have a hoist. Cheers
Dump pipe removal was not easy and my only real complaint with the Beaudesert system was the supplied clamp which attaches to the bell housing was a mongrel to fit as it has to be stretched over the pipe and closing it back up to fit the clamp bolt was not fun. Should be supplied already around the pipe.Kev,
Originally posted by 6SPEED View PostI have both the Beaudesert 2.75 exhaust and the upgrade software Steinbauer on my facelift 150, fitted the exhaust myself (on a hoist) took about 2 hours, the hardest part was removing the factory dump from the turbo. Can imagine it would be very difficult at ground levelThe Beaudesert would have to be one of the best fitting exhaust I have fitted/seenThey complement each other, the car is so much smoother and the torque increase is greatI have not had it tuned on the dyno yet as I only got the Steinbauer last week and have gone off on holidays (it is on the factory setting at the moment) I plan on getting it tuned in the next few months[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
There is a guy up here that is re flashing Hilux and Prado ECUs now to tune them instead of chipping with outstanding results with the added benefit of being able to delete EGR as well that has done extensive research on the dyno who says there is absolutely no advantage of a bigger that standard exhaust system
I personally would beg the differ, to me i found the exhaust made a difference - especially after chipping it on my D4D Hilux,
on my 2014 Prado i have only exhausted it, using the MANTA system it works well. Like mentioned before, the diff and turbo nuts are a problem spot, even on ramps u need more swing over the diff.
how does warranty go with re-flashing the ECU's ??
Hi Mozz, any more info on that or does he have a website?Jeff. 2013 GXL Diesel. ARB Bar, Safari snorkel, Tigerz 12000lb winch, OME 2" lift, Aux battery with CTEC 12v -12v and solar charger, 100w solar panel, Rhino bars, shovel holder, Oztrail canopy, Maxtrax, GME 3220, Toyota tow bar, Tekonsha Prodigy, Hema navigator, Tyredogs, Waeco 50l fridge, ARB compressor, Rear door table, Fire extinguishers front and rear, cig plug and 2 Anderson plugs in rear.
Yea the joys of a Toyota dealers,
they started to suggest that because of my 3" exhaust it would void warranty, i requested them to put it in writing and signed by the general manager...
they refused to do that. - not sure why - i figure everyone likes to talk tough but writing and signing different story.
they can only refuse warranty if the exhaust causes issues directly affecting the car.
therefore they couldn't defer warranty on your brake pads seeing it has no way of relating to your exhaust. (example)
talking about the wobble on the exhaust rusty, i need to do mine on the manta also, it wobbles too much, for a fabricator to like.
no big deal - just a pain in the bum.
