Suction Control Valve "recall"
  • Suction Control Valve "recall"
    Hi guys, has anyone else received their recall notice from Toyota this week advising to book their car in to remove and replace the suction control valve. If so how long does Toyota require the car for? Yet another problem to fix with the D4D motor!!
    What does your letter say? What year model D4D do you have.
    Terry
    Canberra
      Changing the SCV is usually done post-injector change, have you changes the injectors or sheets with the dealer recently?
      Micheal.
        Hi Terry I have a late 2014 VX D4D with only 4500klms and contents of letter basically describes if the SCV fails the ECM detects a fault and puts the engine in limp mode. It goes on to say if this occurs shut the engine down and restart. I have it booked into my local Toyota dealer in early March.
        Regards
        Muzz
          Hi Micheal
          All I have done so far is book the car in for this recall in early March. The guys at Toyota were somewhat taken back .i.e not yet aware of this recall.
          Regards
          Muzz
            Hi Muzz,
            Any update on this 'recall'
            Micheal.
              I wonder if I can keep the old SCV, I might install it on the missus, can't be any worse than whatevers installed and obviously broken at the moment.....
              mlc.... might go make the bed in the dog house before one of you mongrels tell her about this post.....
                You dont wont that - a faulty SCV probably wont have any suction...
                Micheal.
                  Common issue that is lol.....
                    .... my current point exactly........ it can only get better from here.
                    Footnote: if I am to be sinned binned for these posts I want to plead temporary insanity and let the members decide. Given most are males I'm bound to get a fair, if not somewhat biased trial.
                    MidLifeCrisis
                    Out of control poster!
                      Quick Update:
                      First off, apologies to Muzz. On the serious side we would like to know how it worked out.
                      Now, I found a place where for a small fee you get to "test" various installed SCV's!!
                      Depending upon the unit it has been fitted too the prices can get a little hefty.
