Ok guys in the know, maybe I have just over saturated my self with the threads about engine failure, egr valves and so on. What are steps I should take to try and make this engine last and run smoothly, don't really have the cash to replace it, to be honest if it failed and was gonna cost over $20000 I would consider an ls conversion.
Making 1kd last.
Put the plate in.Originally posted by ryzee View PostOk guys in the know, maybe I have just over saturated my self with the threads about engine failure, egr valves and so on. What are steps I should take to try and make this engine last and run smoothly, don't really have the cash to replace it, to be honest if it failed and was gonna cost over $20000 I would consider an ls conversion.
Change oil, air & fuel filters regularly as required.
Injector replacement due at 120k, then you will have fresh full DLC genuine DENSO injectors.
Full diagnostics every service.
If you do happen to find someone decent to do the injectors I would love to know. I'm in Perth as well and looking at getting the same thing done to my 150 series.Originally posted by ryzee View PostThanks mate, what does DLC mean, I also read somewhere that checking valve clearances should be done regular basis? can anyone recommend a good diesel mechanic in perth cause I don't suppose you would be making and trips over here ####. What is the rough price for a set of injectors.
From reading around on this forum the 3 places I've heard mentioned are:
- United https://www.unitedfuel.com.au/
- Allied http://www.allieddieselwa.com.au/services
- A1 Diesel http://www.a1diesel.com.au/location.php
I think DLC stands for diamond like coating and a rough price for a set of injectors fitted is around $2,500
Wooo....... that's a bit, what does blueprint mean, I see that baileys say theirs are blueprinted but I think they are reconditioned, does that make any difference. Lift kit and exhaust might have to go on hold if that's what injectors cost cause they more important, I heard united is supposed to be good will give them a call tomorrow and ask about replacing and if they can do a diagnosis of how they are, if they need replacing yet.I have heard of them failing under 100k and others lasting up around 200k, so not really sure of what to do.Last edited by ryzee; 23-03-2017, 10:09 PM.
New genuine parts are the go. They are DLC coated. New Injectors = new pipes.Originally posted by ryzee View PostWooo....... that's a bit, what does blueprint mean, I see that baileys say theirs are blueprinted but I think they are reconditioned, does that make any difference. Lift kit and exhaust might have to go on hold if that's what injectors cost cause they more important, I heard united is supposed to be good will give them a call tomorrow and ask about replacing and if they can do a diagnosis of how they are, if they need replacing yet.I have heard of them failing under 100k and others lasting up around 200k, so not really sure of what to do.
DLC is a coating which is hard & slippery. Which equals long life!
Injectors, pipes & gasket kit available, but in respect for advertising rules, I won't put my price, you will have to p.m me your number & I will contact you with details & a price.Originally posted by ryzee View PostThanks mate, what does DLC mean, I also read somewhere that checking valve clearances should be done regular basis? can anyone recommend a good diesel mechanic in perth cause I don't suppose you would be making and trips over here ####. What is the rough price for a set of injectors.
Please p.m your number & I will sort it.Originally posted by Frazzy_goreng View PostAny chance you could pm me your price for this? Thanks
Need a few to be feasible.Originally posted by Rhino182 View PostSounds like you need to make a trip over here #### to do some injector work
I did Perth in 2015, probably could do again, but not anytime soon.
Who has a shed, benches, guest room and good cook?
The hospitality we received in Mandurah in 2015 was second to none, awesome lamb roast too
awesome people.
You know who you are, Jobs like that motivate me to do more.......
