What is the difference between the diesel engines in the Hilux and Prado? Toyota quotes 126Kw and 343Nm for the Hilux and 127Kw and 410Nm for the Prado.
Diesel Engine Specs.
Re: Diesel Engine Specs.
Different ECU controlling the thing. Toned down in the Hilux as there is significantly less weight behind it than the Prado,[COLOR=#000080]Nick[/COLOR]
Originally posted by SchafferDifferent ECU controlling the thing. Toned down in the Hilux as there is significantly less weight behind it than the Prado,
Recipe: Add one ECU from written off Prado and get a major performance boost for your Hilux :^)
T
