Hi all,
During the injector change a compression test was done on my 3.0l diesel engine. I would like to double check the values with you guys.
Here they are:
No 1: 20 kg/cm2 or about 280 psi
No 2: 18 kg/cm2 or about 260 psi
No 3: 18 kg/cm2 or about 260 psi
No 4: 20 kg/cm or about 290 psi
Are they ok? Alternatively I appreciate a hint where I can find the standard values. Could not find them in a google search. Thank you for your help.
Thomas
Here they are:
Thomas
