Hi there I would like to know if anyone has fitted a turbo timer to a push button start/keyless enter 150series 2012 Prado, if so how did you wire it up.
thank you in advance
Ken
You'll need to figure out a way to override the keyless ignition system. I'm sure some car ICE places have done it, but wont be an easy job I'd imagine.
Also illegal to leave a car running unattended nowadays in most states. If you are running your turbo that hot, then you need to likely change driving styles in reality. Todays turbos are quite fine with the stop start we do. If you pull off a highway into a park or servo, idle it down for a couple mins before getting out.
