P0400 after 7mm hole plate
  • P0400 after 7mm hole plate
    Hello from the "other side of the world"(Finland).
    I have a Prado 2012 150 with D4D. Few weeks ago I did the EGR clean and installed a plate with 7mm hole. In my car the EGR was electronic so I had to take the egr cooler off so I could get the elbow removed and cleaned. When the EGR cooler was in my hand I noticed there was a little crack in the weld of the bybass tube where some of the exhaust gases had been leaking out.
    Since I was going to but the plate in anyway I figured I will not do anything to the crack.
    After the EGR clean everything was okay until one day after the car had been on idle for a quite long time I got the code P0400. The code has come up in maybe 4 times in this past 1.5monts even tough the car is driven every day.
    Is it possible that because of the leak from the egr cooler bybass tube + 7mm plate, there is not enough gas flowing and that will give the P0400 code?
    Or what could be the cause of the code?
    Attached the Freeze frame data.
    Sledgeh
    Moderated member
