Unusual engine noise 1000-1500RPM
  • Unusual engine noise 1000-1500RPM
    Over the past month my engine has developed a strange noise between 1000-1500RPM. The noise is only present when the engine is hot.
    Below is a link to a recording of the noise.
    https://vocaroo.com/1beqgkWiyIjC
    krypto
    [B]Steve[/B]
    Deleted
    [B]Steve[/B]
      Could it be that it's not the engine but some other thing resonating - like a failed spotweld of a panel?
      Can you feel a vibration with the noise?
        I was thinking that but having trouble tracking down the source of the noise
        [B]Steve[/B]
          Unfortunately not... really loud yesterday after a long drive up north, first thing this morning it was gone and came back when the engine heated up.
          [B]Steve[/B]
            For anyone coming across this with a similar problem. Turned out the noise is the Provent 200 Relief Valve fluttering. Solution is to stretch the Relief Valve spring a bit or get an upgraded heavy duty spring from Western Filters.
            https://www.youtube.com/watch?v=9JBNG_Ac8wM
            [B]Steve[/B]
              Does the engine appear to have more blow by pressure now? That may have caused the valve to be "relieving"?
                It's a new engine (long motor), cracked piston It has used almost no oil in 10km, and no visible blow by. Best of all the oil was still gold coloured when I did the oil change (EGR blank and catch-can).
                Seems this is a common problem and there is a stronger spring available which I have ordered.
                [B]Steve[/B]
