2014 1KD-FTE Oil Leak Common Rail Pump $6.5k fix
  • 2014 1KD-FTE Oil Leak Common Rail Pump $6.5k fix
    Hi all, my 2014 prado 1KD-FTE with 260,000kms on it had an oil leak develop a month back. Mechanic helped me diagnose and provided a $6.5k quote to fix.
    Does this sound about right?
    $2,200 - Labour
    $328 - Timing case outer
    $478 - time case inner
    $1951 - Common rail pump
    $152 - Bolts o'rings, studs & nuts
    $307 - Pump drive gear
    $113 - Pump drive gear bearing
    $100 - seals
    $140 - coolant
    $119 - engine oil
    $20 - oil filter
    plus another 10% on top for GST.
    Is there anything else I should consider doing while this is being done? Thanks for any advice you can offer.
    I question why they want to replace the inner and outer timing cases, pump drive gear and bearing.
    While I personally have not rebuilt a 1KD-FTE pump however I have yet to see a engine that requires those components replaced for an oil leak.
    I would be looking for an diesel injection specialist to do the work, pump price is excessive to in my opinion.
    Lee
      Get a second opinion and if still the same diagnosis then go the whole hog & just get a new motor which will not be much more than your first quote
