Can anyone point me to instructions or tell me how to remove the third row seats to install a bracket for a fridge slide
How to remove 3rd seats
Hi Stumped,
I got this link from another post & used what I found there to remove mine. It doesn't tell you how to do it but it has pictures with arrows.
At times it is confusing but just keep going back to the pictures.
http://www.toyota-tech.eu/Aim.aspx?menuitem=2 Click on the search AIM botton, then "Vehcile" click LC150, "Catagory" intallation manual, then "Accessory Group" down to Towing Hitch wiring Kit, then just pick the top one. This shows the info on pulling out the rear seats.
Good luck
REV
It is a fairly quick and simple job, the instructions make the job look more complex than it is. The symbols are just showing you where the retaining clips are located.
I'd suggest spending $10 on a trim removal tool so that you don't damage any of the plastic trim retaining clips as you remove them. You'll get use out of it on other jobs because every piece of trim is held in by clips.Last edited by krypto; 17-05-2011, 07:18 PM.[B]Steve[/B]
