Had a bit of a weird problem the other day. I did a water crossing in my 150, and the depth was enough that the water was over the bonnet most of the time. A few times it splashed onto the windscreen and (im guessing) soaked into the A/C vents under the wipers.
After this i had a little bit of steam through the vents and afterwards found that the A/C wasnt blowing very much air, regardless of how high the fan was turned up.
After a few hours the problem went away, so im assuming there must be some soft of paper filter in these vents which got wet, and subsequently blocked up by being wet.
Just wondering if anyone else has experienced anything like this? The problem seemed to go away after a few hours, and its working fine now, so im not overly concerned, but as mentioned was curious to see if anyone else had a problem like this?
Im aware of proper techniques to create the bow wave, however this was a little hard to do given the depth
