Squeak coming from rear door latch area
  • Squeak coming from rear door latch area
    Has anyone else found a squeak coming from this area?
    I sat in the cargo area while my wife was doing laps around a the streets and it seems to be coming from behind the rear left tail light area / or door latch area. I checked the jack wasnt loose but ist nice and secure.
    any thoughts?
    Have 120 series Prado with an anoying squeek coming from same area, removed rear wheel and noise went, after doing the same and more (in the back seat, no jack, removed rubbers, tools everything). Needless to say I replaced the wheel but ever since I got some AMTS spacers its been dead quiet now, was either the type of bolt or the foam between spacer and car body that eliminated noise! May be the same with 150's but do a search on the forums, its been an ongoing annoyance on the 150s more so apparently and I have seen plenty of threads on this site!
    2005 GXL, TJM Bar, 2" Tough Dogs, Narva Spots, GME UHF Radio, Warn Winch, BFG AT's, Dual Battery, Red Arc BMS, Safari Snorkel, ARB air, Piranna Breathers, Rhino RR, Waeco 50lt, XTM recovery, Open Sky Awning - towing a Customerline Camper Trailer!
      Theres a slide latch that makes sure the door lines up when closing, clean it out and see if that makes any difference.
      [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
        Have you looked for mouse droppings?
          yep! that must have been it. thank you.
          before seeing your email i lubed up the latch and all contact points (rubber stops etc) so now I'm not sure which one was causing the problem but my guess would be the latch also.
          thanks for your input
